24V System Troubles
VIP93
I have a 1993 VIP with a 2-12 12/24V switch in the bow that has been unplugged and now I don't know how to wire it back into the trolling motor system. Can anyone tell me how it is suppose to be wired or maybe have a diagram? There are six posts on the back and the switch has two positions. One is the 2-12V Charge position and the other is the 12/24V position.
Silvertip
Honorary Supreme Mariner
Re: 24V System Troubles
There are several different wiring schemes for this system. You said the switch has six terminals which is fairly standard. But because it has six terminals, it does not mean all of them are used. The more important question is how many wires do you see and what are the wire colors. Then the next question is how many wires leave the switch and to the trolling motor receptacle and what color are they. Pictures help here.
VIP93
There are two black wires, one red, and one orange. I'm not sure where they go because they weren't hooked up. It looks like someone bypassed the switch at one time. There is one black wire, one red one, and one orange one on the back of the plug for my trolling motor. Can I still hook the switch back up or should I just bypass it again?
Silvertip
I'm going to need to sneak up on this one so I'll keep asking questions and fill in the blanks as we go. We know you currently have a 12/24 motor because of the three wires from it to the plug. Next question: Do you plan to use the 12 volt function? If not, you don't need the switch. So here is the breakdown for the three motor wires:
Black = ground
Red = 24 volts (measured to black)
Orange = 12 volts (measured to black)
The wires from the batteries are paired as follows:
Black and red come from one battery
Black and orange come from the second batteryl
You need to determine which black wire is from the negative post on which battery. You need a test light, voltmeter, or ohmmeter to determine this if you can't determine it visually. Measure from the red lead to one of the black leads. If you get a reading, those two wires are paired. If you get no reading, measure from the red wire to the other black wire to verify. No need to measure the orange and other black as you've proven what the pairs are. Tag those wires BAT 1 NEG, BAT 1 POS, BAT 2 NEG and BAT 2 POS. It doesn't matter which battery you identify as BAT 1 and BAT 2.
Now then, you said it looks like they tried to bypass the switch. By that do you mean there are other wires that look added or messed with, or are just referring to these four?
I now need to know if the wires from the receptacle on the boat are connected to the switch or are they just hanging free as well.
Problem: I don't see how you can get 12v and 24 from the same switch setting so please look at the switch label carefully and confirm what you see.
VIP93
My trolling motor does not use 12V so I'm pretty sure I can just wire it strait 24V from the batteries. I'm pretty sure I know how to do that from reading the other posts and diagrams. Although I am still interested in how to wire the switch if I ever need it because I am looking to get a new trolling motor.
Just from what you have told me the switch acts as the source for 24V? There is a battery 1 set of wires that is 12V to the switch and then there is battery 2 set of wires going to the switch that is 12V and by hooking it up right the switch will provide 24V to the motor? The plug in wires were hanging free as well so I'm not sure how they are suppose to be hooked up.
There are three wires, one black, one orange, one red.
On the front of the switch one position is labeled 2-12 charge, the other position is labeled 12/24.
I hope I did not confuse you. It's not a huge deal if we can't get the switch figured out because I can just wire it strait 24V if we have to.
Silvertip
If you are planning on a new motor you will not find a 12/24 so there is nothing inherently wrong with bypassing the switch for straight 24 volt operation. I simply do not have enough to go on here. I do have a diagram that provides 12 or 24 volts for a two wire system to the motor but it would have to be modified for a three wire system to pick up the orange wire. I'll look at and see what I can do. If I'm not back with an answer in a day or two, feel free to PM me with a reminder.
(For others -- this is not an open invitation for PMs on individual problems.)
VIP93
That sounds good to me. I appreciate all your help thus far and have found all the information useful as well as looking at other postings on this web site. I appreciate your time and i am sure i will use this website in the future if any other problems arise which usually happens with an older boat :). I have also found some items in the store I plan on purchasing. Thanks again.
