- Sep 22, 2003
- 28,772
Re: 24 volt trolling motor wiring
If you are picking 12 volts off a 24 volt system you had better be very careful which battery you pluck it from. Either battery will work, but if you pull 12 volts from the same battery the +24 volt line is coming from you risk serious damage to 12 volt accessories due to an accidental ground situation. This has been discussed and a diagram has been posted in this forum in the last couple of weeks. Look for it
