24 ft martinique electrical manual needed
meleconn
looking for manual getting shocked on bowrail 13 V trying to tracj down wiring
meleconn
Re: 24 ft martinique electrical manual needed
I had that same problem a few years ago. traced wiring, found the wires to front berth light were touching a rub rail screw on starboard side. Wires ran along wall at rub rail area, screw had corroded & made contact w/ wire. Removed interior at shower area wall, found damaged section.Cut wire, removed, problem solved. Had to run new wires to front.
hope this helps
ps boat is a 1999
