228 mercruiser water in oil problem
osborne looney
1979 mercruiser 228 (gm 305) purchased boat with severly cracked block on both outsides --frost plugs DID NOT BLOW -- repaired cracks with world famous J/B WELD held great NO LEAKS !!!! problem occoured when put muffs on lower -- ran great for 5 min's or so -- I shut it down went got more gas re-started / started hard then milkey oil (water in oil) comes out of rocker cover vents !!!!! head gasket ? or is it possible for block to crack on INSIDE ? has anyone had a block crack on inside water jackets ?
Re: 228 mercruiser water in oil problem
Ayuh,... That's where it Usually happens...
'cause their Not frost plugs, they're Core plugs...
meesh
Absolutely on the inside.
jimh1626
Yep. Had it happen. That's where it usually happens. Don't trust JB Weld. While it is good stuff, I wouldn't trust it on a boat. Get it welded, or get a re-manufactured block. I spent $500 on welds and machining and still couldn't trust the old block, so I bought a long block from Auto-Zone for $1600. Not only will I be secure, but it will make resale higher.
Jim
