22 Foot Starcraft Chieftain I/o to Outboard Conversion
Hi guys, My name is Captain Marcus. I'm 31 years old , Cleveland Ohio and got my Masters Captain License back in March 2017. I have been restoring aluminum boats for about 7 years now I have always purchased outboard hulls until now.
I recently purchased a Chieftain with 260 v8 stern drive setup. Rotted transom, rotted deck, mediocre foam etc. I have a 100hp Johnson outboard in the garage and a 70hp evinrude vro with tilt as options.
I'm also a certified aluminum tig welder so making repairs to the hull should be manageable. I'm redoing the floor in 3/16 diamond plate from stern to the bulkheads at cabin entry.
My thing is fabbing a Splashwell , Inboard patch , 20 inch transom Outboard cutout and knee braces To accommodate an outboard motor.
I've cut a template for I/o patch so far but haven't moved to cutting the transom 20 inches yet. I am wondering what size opening should I go with for outboard. A wide opening to acomodate two engines or a small opening that will give clearance for the single outboard.
Bigger cuttout would equate to a bigger splashwell and more material. I'm stuck.
GA_Boater
Welcome aboard.
Have you thought about using your skills to fab a bracket? The knee braces are still needed and the big hole needs patched, but no cutting of the transom is involved. And the cockpit gains more room.
Welcome aboard.
I haven't done enough research on brackets on my boats layout. Will the center of gravity change? Pros vs Cons
GA_Boater
You throw out over 1000 pounds of IO and add maybe 500 pounds with 2 motors about 12-18" off the stern. It ends about a wash as far as balance on the boat.
82rude
Whatever you decide to do please document on here id love to see the process and results.
GA_Boater
Click Forum Help in my sig and look at posting pics. You need 3 posts or more posts and you can add them now on your 4th post.
No Title
63cruiser
If your going to use a 20" outboard cut there. I did about the same conversion. I welded the transom from square aluminum. It turned out very strong. I used full width splash well to mount a kicker motor next to main motor. Also I have a 140 hp Johnson and mine only runs about 30.
