20hp rough idle
chriscamp612
I have a 1990 20hp Johnson 2 stroke model J20EESB. Starts right up, idols rough spits and dies unless i raise idol on controls. runs good but slow down then put in neutral it will spit and die. I have changed spark plugs and wires. Cleaned filter screen at the fuel pump and replaced all fuel line and the fuel tank. if you run this engine wide open the overheat horn comes on but not loud just a little. Got any ideas?
Mas
Re: 20hp rough idle
How is the motor pumping water? When was the last time the impeller was replaced?...if not in the last three years, replace it! How about the thermostat?
MAS
