- Apr 13, 2005
- 781
Hello all.... I just bought a new boat with a Yamaha 300hp outboard (my first outboard in a long time) and I'm trying to get it connected to my NMEA 2000 backbone so I can see engine data on the chartplotter. I searched this forum and the Internet and the information is not clear to me.
As I understand it command link uses NMEA2k and if I remove the NMEA cable from the Yamaha gauge (touchscreen, color, single display, 6yc I believe) and connect it to the backbone the Garmin identifies the engine but since it wasn't in the water I didn't start it to see if there was any data. I did not see the battery voltage or any temperatures from the engine so I'm guessing it was only partially successful. If I then added another cable from the backbone to the 6yc it didn't light up, presumably because it needs to get power from the bus which is not provided by the NMEA backbone or because it wasn't able to talk to the engine on the Yamaha bus.
From what I have seen there are three ways to make this happen but I don't know which is the right one. First, and my preferred, would be to use a cable that has the Yamaha connector on one end and NMEA2k on the other and connects the bus to the backbone. Simple and cheap. Second would be to find the connector on the engine and use that BUT I'm fairly certain that there's only one and it's used to connect to the bus which I assume is how the throttle, key and trim are all connected so I don't know if this is an option. Last, and my least favorite, would be to use a "Gateway" box to extend the Yamaha bus to the NMEA backbone.
Since I already have the Yamaha to NMEA cable I want to try it but the question is where do I plug it into the Yamaha bus? There are device ports and bus ports and from what I have found the bus ports are for extending the bus and are where I would connect the gateway (according to page 3 of this doc https://continuouswave.com/whaler/reference/Yamaha/Yamaha_Engine_NMEA_2000_Connection.pdf) but it requires removing the already installed terminator. I also believe the bus ports are 6 pin instead of 4 pin like the device ports but I'm not sure. Since the NMEA backbone is terminated I would guess that this is not a problem but I really don't know. Can I simply plug it into a device port to receive the data? That's how the CL display is connected.
