Green for heat 2. Elliott leads Truex, it's close.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #41 Green for heat 2. Elliott leads Truex, it's close.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #42 Elliott was cruising in front and Truex ate his lead and closed up on the 9. The 19 now leads.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #43 Yellow for Houff losing RF tire and into wall. Leaders pit.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #44 Elliott out 1st, Harvick second.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #45 Back to green - Elliot and Larson clear Harvick.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #46 LF down for Stenhouse. Got it to the pits safely under yellow.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #47 Elliot and Harvick on front row for restart. Elliott leads and Harvick fell to 4th. 40 to go in 2nd heat.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #48 Briscoe wrecks from 12. TWT may have helped. Leaders pit again.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #49 Larson, then Elliott out of pits 1st. Some stayed out.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #50 29 to go and green. Larson and Elliott shot to the front.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #51 Larson wins 2nd heat.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #52 The 4 champ drivers are in spots 1 to 4. Larson, Elliott, Truex and Hamlin. It should be getting crazy. Larson, Elliott. Hamlin,. Truex is the running order.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #53 Elliott is trying to clear Larson for the lead with 75 to go. Cleared. Hamlin is 1.3 back and Truex is 2.6.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #54 Hamlin to 2nd over Larson.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #55 Green flag stops with Truex in the pits and Alfredo smack the wall hard. Don't know where Truex will end up.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #56 Hamlin 1st out of the pits, then Elliott Joey and Larson. Truex is the leader when the flag drops.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #57 55 laps to go - Truex, Hamlin, Elliott ans Larson.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #58 Truex was leading and Starr loses a brake rotor. A yellow changes everything.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #59 Larson out 1st , from 4th to 1st.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Nov 7, 2021 #60 25 to go on green. Larson a good start. Then Truex, Hamlin, Elliott. The 9 around the 11.
