Elliott is the leader with 7 to go in the heat.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #41 Elliott is the leader with 7 to go in the heat.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #42 It's nuts up front! Oooops yellow. 3 to go in heat.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #43 Joey pushed Almirola almost into the wall, maybe into the wall. With all the checking up, 6 cars get damage, Almirola and TWT may have the worst.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #44 Buescher wins his first heat under yellow. TWT was flying low, off the ground, during the wrecking. Elliott 1st out of the pits and will lead the restart.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #45 Elliott and Keso on front row - Green flag for heat 2.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #46 Caution for TWT. Blew the left front and left metal bits all over the track. 0 for 2020 continues!
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #47 Restart for Buescher and Keso.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #48 Now Jones to the lead with help from Elliott when Matt D does a good wiggle while getting a push.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #49 Green flag stops begin and a debris caution comes out.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #50 The debris was part of a Blaney tire chunk and rubbing the wall real good. Jayski tweet; Me: Caution Twitter: You already tweeted that Me: Caution out Twitter: You already tweeted that Me: Caution back out Twitter: You already tweeted that Wash. Rinse. Repeat.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #51 Elliott and a bunch of Chevys were in the pits when Blaney's caution came out. Lucky!
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #52 Elliott leads on the restart.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #53 The Big One!
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #54 Kurt Busch went over the top of Cole Custer. It began when Bowyer pushed Johnson out of shape. On Slo-Mo, the 14 didn't push the 48. Red flag for cleanup.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #55 13 cars, at least 3 playoff drivers. 6 playoff cars have been damaged today.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #56 Green again. Joey and Matt D go around Elliott.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #57 Truex wins heat 2. Joey penalized for forcing Matt D below the yellow line.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #58 Bubba is leading with 58 to go. Bowman has been pushing everybody and the front of the 88 is all beat up from the 1st lap wreck.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #59 Keso leading now. 52 to go.
GA_Boater Honorary Moderator Emeritus Joined May 24, 2011 Messages 49,038 Oct 4, 2020 #60 Now it's Joey. 50 laps left.
