2017 DF 175 bogs down
BOAT DOCTOR
I have a brand new out of box 2017 DG 175 motor runs fine when trim out and cruising but when I trim it down from 3000 motor bogs down bad like it would be down on power less than one hour on has any one experience this or can give me some pointers to check I'm a oyster fishermen and nearest dealer is 4 hrs away and boat is way to big to trailer back and forth without Police escort thank for any input
99yam40
when you say trim down, are you saying you trim the motor with the Tilt and trim switches?
BOAT DOCTOR
Yes when ever I'm cruising at a rpm above a 1000 and trim down I lose about 200 rpm it I ly does in when I trim down battery is new ,batt cables new came with motor,the white sub cable is new.being that I have twins swap harnesses still did it,swap boxes still did it and swap ECU and still did it.check all ground wires they are tight and clean brand new motor do you think it can be a relay drawing to much current.even tried another trim motor still did I'm at a lost any ideas
99yam40
does it only happen while the T&T motor is running?
when you release the trim down, the motor picks up RPM again?
Your explanation is not the best.
You say you have 2 new motors on the boat, but just one is doing this?
Monitoring voltages and fuel pressures while problems show up should point you in a direction, if they are affecting the motors performance
BOAT DOCTOR
Yes it only happens when I hit that pt&t button down I no its not fuel pressure it stays at 35 psi at idle and 38 psi at 3000 rpm only happens when I trim it down don't have to hold the button can be a quick tap it's like a ground issue but eliminated everything but trim relay and engine harness motor is under warranty but the people at the shop are idiots don't no **** motor is brand new can a defective trim relay cause the Motor to maybe draw more current than it should it is definitely a voltage problem I hit the button down drops 200 rpm and when released picks back up to the normal rpm thanks for your help
99yam40
need to see if voltage to high pressure pump is dropping and causing low pressure to the rail when this drop in RPM happens.\
I do not know what kind of ignition system this Suzuki has.
If it depends on the 12 volts system and it drops due to load of the T&T running against the forward trust of the prop, I would think you could measure that drop where to 12 v input to the ignition system is.
Just remembered you said when you hit the down button not the up, so I do not see any reason for excess load while trimming down in gear.
I do not see how a T&T relay would cause it
hate to say it but let the shop find it
