2013 175 TF Tracker
Dellio1096
I just unhooked the cranking battery from my boat and moved the tray to create room for an additional battery to run fishing lights. When I reconnected the battery, the fuel gauge nor either one of the depth finders as well as the horn, courtesy and nav lights work. The fuses in the fuse block are ok. Help?
DonHof
Re: 2013 175 TF Tracker
Did you hook up all the wires? I have two or three on my battery.
