2012 tracker pro guide v16 sc ignition switch
mkrashin
My ignition switch is broken and needs to be replaced. Does anyone have the wire diagram so that I can use a aftermarket switch? I have 6 wires coming out my switch. It is a 3 position push to choke switch. Bass pro said part number was 129572 and it’s a 140 dollar part. I bought a Sea-Dog 420381-1 Three Position Ignition Switch-Magneto Style. Any help is greatly appreciated.
i did try the search function first but didn’t find anything.
Silvertip
Honorary Supreme Mariner
Unless it has a push to choke feature it won't work. You can get what you need right here on Iboats. If the switch you bought has the push to choke feature, then tell or show us what the terminal markings are and we can figure this out. It would also help if we knew what motor this boat has.
