Re: 2010 Q7 Smart tab install
I mounted the bottom bracket then used an angle measuring tool to set the 25 degrees. I held the actuator with the top bracket against the masking tape while measuring. Once I had 25 degrees, I used a sharpie to make dots in the actuator screw holes. It did take me about awhile side marked. I was a little anal about it. I wish I counted how many times I measured. I didn't want to screw it up!!!
I did the install as directed in the smart tabs instructions. I did not consider that the transom on the boat is angled inward. It probably does increase the angle. Q7idrvr, how did you chance the angle during the install? Was it via the hole you put the actuator in? Or did you change the angle you installed the bracket? If the latter is the answer, how did you do that? Same question to Whitey224.
I have been extremely impressed with Greg at Nauticus. THis is how customers should be treated!! BTW, he is sending me both the 60's and the 40's! I will send back the ones that don't work. Unfortunately, I probably won't get to thy them before our boating vacation, so I will do it at the lake we are going to, Houghton Lake, MI.
