mnfarmer93
Thread starter- Joined
- Jul 11, 2012
- 3
I have a 2010 4.3TKS in a crownline boat that has developed a slight knock at idle sometimes not always. What happen was I was going down the lake at about 3/4 throttle and the tether cord accidently got pulled and the motor got shut down. I restarted it right away, probably should have waited but didn't and noticed no oil pressure. Shut it down and waited a few minutes and started again except this time I had oil pressure but a little lower than normal and a small knock in the motor. I went down the lake a couple of miles half throttle and didn't hear the knock but when I slowed down to dock it appeared. I waited a few hours and started it again and all was good took off down the lake about 20 miles to the trailer and never knocked. Now tonight I take the kids out tubing and I was running good at first now when I shut it off and start it back up sometimes it knocks and sometimes it doesn't. When it is knocking the oil pressure at idle is lower that normal and it fluctuates at 3/4 throttle. I would say the if you start it and it starts to knock the oil pressure is probably around 10 psi and if it isn't knocking about 20. When you are going down the lake at about 3000 to 3300 rpm and the engine was knocking at idle the oil pressure will go up to 40 and fluctuate down to about 35 but if you start it and it isn't knocking at idle it goes up to 40 and stays there. This boat has about 30 hrs on it and the oil looks good but I am going to change it before I take it out again. So did I screw something up in the motor or is it something else?
