200hpdi-2003
Thread starter- Joined
- Jun 28, 2010
- 7
Boat sat more this year than usual probaly about 6 months. Went out last week to fish ran about 25 miles no problems, 4 miles from dock motor would bog down past 4200 rpms, put the boat on the trailer. Replaced fuel filters put fresh fuel in tank, took it back out a week later boat ran find for 6 miles then bogged down at 4200 rpms turn back around head back to dock after 100 yds motor bogged down and would not run much past a fast idle. limped back in about 6 miles at a whoping 6 mph removed cowl and noticed fuel leaking from lower fuel pump, ah found problem removed fuel pump noticed gasket and diaphragm cracked along bottom replaced on on both fuel pumps motor still does not run much past idle, it sputtered and dies. I connected an auxillary tank with fresh fuel directly to the fuel filter under the cowl still ran bad. Starts great just when you advance throttle is will sputter and die. Thanks in advance for any help,
