TBarCYa
Thread starter- Joined
- Apr 13, 2005
- 781
I believe that the fuel that was in my carb from the end of last season has gone bad and gummed things up so I'm planning to disassemble and clean the carb. The question is, do all of the gaskets in this carb need to be replaced or are they good gaskets that can survive a disassembly and still be usable? The engine has about 20hrs on it and a couple quick searches have not revealed a gasket kit.
When I first took it out on Wednesday it ran great for the first couple minutes then it wouldn't rev past 4000rpm. If I set the throttle and let it run, after a minute it would accelerate like crazy for a minute then go back to running bad and continue this cycle the whole time it was moving. I'm going to pull the plugs but I suspect that they're going to tell me that it's running lean.
Any help is greatly appreciated.
Thanks.
Thanks.
