2008 Bayliner 195 BR no power to ignition
Status
Not open for further replies.
jasonbgriffin
I have power to horn, radio, blower and bilge pump....but I turn the key and nothing! What could I be missing? I replaced the battery today and still nothing.
Bt Doctur
Re: 2008 Bayliner 195 BR no power to ignition
and the engine is............................
man overboard switch?
shifter in gear?
Bt Doctur
do you have/know how to use a meter or test light? locate the circuit breaker with the red button. should have power to both connections.if not check the red system wire at the starter for a plastic square block. its another main system fuse
http://www.boatfix.com/merc/Techbk/96/96HGD4.PDF
jasonbgriffin
do you have/know how to use a meter or test light? locate the circuit breaker with the red buttom. should have power to both connections.if not check the red system wire at the starter for a plastic square block. its another main system fuse
where would the circuit breaker be? red bottom? or button?
sorry im new to this and have no idea what to look for.
dingdongs
if you wish to carry electrical fault finding out get yourself a cheap multimeter for $10 and see where you have 12v.we assume theres not a battery isolater switch which has turned a majority of the power off.do you have lights or see or hear the alarm which sounds before starting??????
Jbuck88
I am having this same issue? No sound from ignition switch but all other electronics work. Any ideas ?
GA_Boater
Yes - The idea is to start a new thread with some information. What motor, including a serial number, and what have you tried so far.
Closed - 7 years old is not going to be looked at by the members.
Status
