jasonbgriffin
- Apr 5, 2011
- 3
I have power to horn, radio, blower and bilge pump....but I turn the key and nothing! What could I be missing? I replaced the battery today and still nothing.
do you have/know how to use a meter or test light? locate the circuit breaker with the red buttom. should have power to both connections.if not check the red system wire at the starter for a plastic square block. its another main system fuse
http://www.boatfix.com/merc/Techbk/96/96HGD4.PDF
I am having this same issue? No sound from ignition switch but all other electronics work. Any ideas ?
