2007 Yamaha F150 maintenance indicator
26century
I have a set of 2007 F150 Yamaha's and every 100 hrs. the command link gauges have a maintenance required reminder that scrolls across the digital gauge. I do my own oil ,oil filter,fuel filter,lower unit, etc.Is there away to clear the maintenance minder without a visit to my mechanic, nothing in the owners book about this, and this is just a little thing that bugs me.
rodbolt
Re: 2007 Yamaha F150 maintenance indicator
your engine package should have had the command link quick reference.
I cant do it out of memory but its simple and ill try to post it tomorrow.
Triton II
Below is how I reset the 6Y8 tacho maintenance symbol on my F115, it wouldn't hurt to try as I think the electronics are the same. Good luck,
TII
MAINTENANCE (resetting maintenance
intervals)
You can reset the elapsed time from the
previous maintenance interval (when the
meter was reset).
1. Turn the engine off and the engine start switch to ON.
2. MODE (4 seconds): To activate the custom mode.
3. SET: To switch to the resetting display.
4. SET+MODE (1 second): To reset the elapsed time to ?0h.?
5. SET(1 second): To return to the normal display.
NOTE:
Press the SET button for 1 second from
step 3 to cancel the resetting of the elapsed
time and return to the custom mode selection
display.
rodbolt
its about the same procedure to reset the maint.
do a forum search as I have posted it in the past.
