What type of grease should be used to grease all the lube points on my engine. most all the grease looks like an off white but the long shaft down the center where the motor basically turns on...that grease is grey and seems heavier than normal grease. is this a special kind of grease i need to put in that area or can i use the same grease on the entire engine as far as through the grease fittings. thanks for the help. i just spent an arm and a leg for a 100 hour inspection and i get it back and i have reservations that they even put a grease gun to my engine....hell some of the fittings still have paint in the opening. also, they changed my diode on the lower unit and i'm pretty sure the old one was cocked to the left a little....this one is perfectly straight in the center. i thought they cocked it one way or the other to counter the prop?
