Topcat2vin
- May 13, 2010
- 16
I took my boat out the other day and after a few minutes it blow the hose from the thermostat housing to the engine pump off. I have now removed the housing to check the thermostat and it seem ok. Holes are also ok. I was going to check risers and drained the manifold and block. No water came from block. Could it be the engine pump is not pumping the water?
Thanks for any advise
