Team Kutsh
Thread starter- Joined
- May 11, 2010
- 4
Good evening, I am a first timer on this site and I need some help with my suzuki 4 stroke outboard 200 hp.
The problem began last week when all of a sudden at full throttle the engine started to cut back and loose power. normal speed is 36 mph and I was down to 18mph. The next day I changed the plugs, discovered there was some water in the filter. Day 2, I left the dock and got stranded, boat shut off. I discovered there was a crimp in the fuel line and the bulb seemed flat. I straightend the line and tapped the bulb. The boat ran great for two days. Now it doing the same thing again. I have replaced the bulb and checked the fuel filter, no water found. At this point when I hit the gas it boggs down at 3000 rpms and revs up and down. I feel this is a simple fix, however, I am at a loss for what to try next. Any suggestions?
