2007 4.3 Trim relay clicks, no start.
Stormin Norman C
Hi Guys, on my '07 4.3 I went to the boat ramp, started her up and ran for 20 minutes and turned the engine off. Tried to start her up 10 minutes later and all I heard was 1 click, but... coming from the trim relay by the carburetor. I've cleaned every wire connection, replaced the trim relay, starter, and 90 amp battery terminal fuse. I discovered 2 solenoids by the trim pump, is that the slave solenoid? Will those solenoids affect start up if they go bad? Thank you!!!
alldodge
That's the starter slave relay, and its probably gone bad
alldodge
You said by the carb, which it should look like this
And there should just be one. Down by the trim pump there are also 2 of the above ones which are the same and are trim relays. The trim relays have nothing to do with a motor starting
tpenfield
@Stormin Norman C
The starter and the trim pumps use the same relays. The trim pump has 2 of them and therre is 1 for the starter. It sounds like you need to replace the starter relay. (right?)
Stormin Norman C
I've searched for another solenoid and can't seem to locate it, wonder if it was removed when I had my carbs rebuilt, there are 2 leads that don't go on anything. I'll take a pick. Thank you Sir!
Stormin Norman C
Here's the relay that clicks when the key is turned on.
alldodge
OK, new style slave relay. We always like serial numbers so we know exactly what were working on
Take that to the local auto parts store and have them get you one
Or can search for "Mercruiser 882751"
nola mike
That looks like just a standard auto SPDT fuel pump/whatever relay. But problem could be with the starter, starter solenoid, wiring. Go through the troubleshooting first in the stickies. Or don't, it's a $5 part that takes 30 seconds to swap...
Stormin Norman C
That is a new part, guess it could be bad or something shorting it out?
nola mike
Then it would appear that you wasted $5 and 30 seconds.
Start here:
alldodge
Ok, then with key turned to start wiggle the shifter back and forth slightly. If it cranks then its the neutral safety or its adjustment
nola mike
Shouldn't be any power to the relay with an open NS switch, so no click.
alldodge
Agree, if its open or has a bad connection. The NS switch connects the yellow/red wire from the start side of the key switch thru the NNS to the start relay. The switch closes when in neutral so its safe to start
Stormin Norman C
Start here:
Wow awesome guide Thank you!!!!!!
