2007 3350 mpi not reaching top rpm
willie001
replaced long block after manifold failure. engine now will only reach 4200 rpm. runs smooth just will not reach the 5000 range that it did when it was new. fuel and filter are good. it reaches 4200 at about 2/3 throttle position. when pushing throttleto full no more gain is achieved. heads have been checked and valves adjusted. any suggestions at what to do next
alldodge
Howdy
I would start by checking if the distributor was installed correctly
If that is correct, check fuel pressure and does the throttle body fully open at WOT
kenny nunez
Hopefully the above post has solved your problem. If it did not where did the engine come from that you installed ?
