2006 Volvo 5.7 osi-d crank no start
alldodge
Putting a high pressure oil pump in a motor not designed for it just causes more oil to be dumped back to the oil pan. Will increase the heat some due to the higher pressure. High pressure will not harm bearings, its the high heat that can cause the oil to fail "IF" it gets to hot, and again yours is not high it looks fine even if it is 60.
