2006 Tohatsu 40 hp TLDI Warning Lights on!
leavitt4u2
The lights stay on(all three) then go off every 3 to 3.5 seconds.I have reset ecu and TPS .I bought new 1000 MCA Battery.The motor runs fine no rough or any hesitation either.I have looked at all the connections as well. I guess I will change the plugs also. I have not bought a manual as I have had the motor only 1 month and they never came on until recently. The tach works fine and I have inspected the cables from the controls and the tach.Please let me know if any info .I am taking the boat to the dealer on Monday but I would at least like to know if any there are any solutions to the problem.Thanks in advanced.
Larry in Florida:D:D
TOHATSU GURU
Re: 2006 Tohatsu 40 hp TLDI Warning Lights on!
Larry,
Using the manual is the only way to put the engine into it's self diagnostic to determine if you have a problem or what that problem might be. There are no shortcuts on modern engine troubleshooting.
pvanv
Larry,
I have to second Elvin's motion.
leavitt4u2
Thanks , You guys I just thought I might be able to shed some light on it.I will make getting a service manual a priority also.
Thanks again,
Larry
