2006 opitmax- neutral switch starting issues
dstnlandry
I have a 2006 optimax 90hp. I’m working thru a rough idle issues so it does in gear sometime. When it does I’m stuck “in gear” and it won’t start. I have to go from forward, reverse way to many times to get to neutral to start. Sometimes I’ll kill it in neutral and still have issues starting.
if I pull the cowling and manually move the gear slide on the side of the motor it will reset.
I’m not 100% if it’s a gear issue or a neutral switch issue. Any advice before i start replacing stuff? Neutral switch? Shift cables?
thanks in advance for the help.
