2006 mercury 90hp 4 stroke efi fuel issues please help!!!!!!
ghoover05
Alright here's the issue.
just got the boat.
It idled great, putted around a bit ran great,and full open ran great, 42ish mph on a lowe 175fs. for about an hour.
then it happened... it started to act like i ran out of fuel and died. was able to get it started a few times and putt back to dock this took a while more than five minutes between idle runs. with a new (used) boat the dealer told me it had 2/3 tank by guage. i thought in my haste to not try to fill it up maybe the gas guage was broke. it only took 15 gal to fill. specs say 27 gal tank.
I seen posts about filters, water seps, and vapor canister things but i don't have a manual or know what these items are.
I know where the fuel filter is but unsure about the other items.
Also i read something about the fuel tank mounted pump.
Thats all the info i have right now it got too dark.
anyone have any ideas?
if you have the fuel system diagram that would help or pics of items.
PS the motor only has 206 hours on it and the dealer said the o scope looked great.
carholme
Re: 2006 mercury 90hp 4 stroke efi fuel issues please help!!!!!!
What is your engine s/n?
Gerry
ghoover05
1B355938 does that sound right?
theoldwizard1
  • Drain as much of the remaining fuel as possible from the tank
  • Change the fuel filter.
  • Put about 10 gallons of fresh gas in the tank
  • Add a full can of SeaFoam
  • Start and let idle for at least 10-15 minutes.
  • Launch and run the rpms up and down under load
This fixed my 2001 115hp Mercurty EFI (basically the the same engine).
carholme
ghoover05
thanks for the info. i was too slow on the book but ill keep my eye out.
thanks again
