2006 5.0GL-F (AQ) Electrical schematic needed - Fuel issues
curtiscruising
I'm not getting power to the electric fuel pump when turning engine over. I replaced the fuel pump relay. Fuses check out good as well as circuit breaker. It will run with starting fluid for a few seconds. I've found the two diodes in the harness. they epoxied them in so not sure I can pull them out to test with meter. Any words of wisdom on this 2006 Larson 223?
Troy
alldodge
Hot wire the fuel pump for 10 seconds or so
If motor starts and runs without issue then its a fuel pump problem. If this doesn't get it running then its ignition or the pump is not pumping fuel
