2006 30HP Mercury telltail problem
GA_Boater
Welcome aboard, John,
How are you supplying water to the motor? Muffs or a barrel?
If a barrel, how deep is the motor in the water? It must be well above the parting line between the lower unit and mid-section.
JohnA47
First of all, thank you for your greeting.
I am putting the cooling water in the engine by muffs.
Hope to hear from you by tomorrow.
Thanks John
QBhoy
John. Are you getting water pumped and back through the lower unit outlets but not the tell tale ? Or nothing at all returning anywhere ? Often the tell tale can get blocked with salt but the engine still cools and flows water through the main channels and out through lower unit. Have a look. If it’s not coming out anywhere...that’s when to worry. Then you either have badly fitting muffs...or a worn impeller
