2006 290 Horizon Water Pump Replacement
mkeach
Any advice on replacing the water circulating pump on a 496 Mercruiser in a 290 Horizon? Took off the floor panel but the gas tank still makes it impossible to get to the front of the engine to access the pump. Can you access it better if you remove the heat exchanger or am I going to have to slide the fuel tank out of the way.
