2005 Tracker Tundra Electrical Help Please!
Royale With Cheese
I have a 2005 Tracker Tundra 18 and I am experiencing a strange electrical problem.
When I plug something into the 12v outlet at the helm, a 12v inflator, in this case, it runs at about half power and the recirculating pump comes on when I turn the inflator on.
When I turn the inflator off the recirculating pump turns off, but the pump will work via the switch as it should.
This started happening out of the blue. Nothing changed or added.
All fuses are good.
When looking at the wiring, I noticed that the ground for the recirculation switch and 12v outlet jumper to each other and both go to this timer. Could it be bad?
Lastly, should the lights on the gauges be on as soon as ti turn the ignition key to run? I thought that they only came on when turning on the Nav or Anchor lights.
Thanks, for your help.
