Mike_Berry
Thread starter- Joined
- Feb 21, 2008
- 25
I took the lower unit off with no problems. I replaced the impeller and for the life of me i can't get the lower unit all the way back in. The shift rod isn't hitting at the top before it goes through the hole. I'm not in far enough to where the water tube that goes into the pump housing isn't hitting yet. It's acting like the main shaft splines aren't going in. I tried turning the motor over very slowly and also tried turning the prop with it in gear. It won't go in. Any idea's guys?
Thank you
Thank you
