2005 Tohatsu 6 hp no forward or reverse
riffraff
I had to replace my lower end gears. I thought that I put it back just the way that It was. Now I have no reverse or neutral.
I just double checked and the clutch spring retainer is on the spring side of the spring pin. So I think that is ok.......HMMM???? Help would be much appreciated. Thanks, :confused:
TOHATSU GURU
Re: 2005 Tohatsu 6 hp no forward or reverse
See your service manual or look at the free parts diagrams at internetoutboards.com
pvanv
The spring retainer (short piece of shafting, almost square) rides against the push rod, so it sounds like you have it in the wrong place.
riffraff
Thanks Paul, For not just giving me one Liners.
I will try that. Mitch
TOHATSU GURU
Telling you where to look at a diagram of how it goes together is a one liner...It's the one liner that you needed. Your welcome by the way.
