bballfan77
Thread starter- Joined
- Nov 12, 2011
- 18
OK. I purchased this motor 3 weeks ago and finally got a chance to install on my 16" 1984 Grumman 5.0 center console.
After install I Barrel started it and let it idle......no problems.
1st time on water everything OK up to the point where I tried to go fast. The motor is not getting up to speed. 8 MPH per GPS.
I do not have an rpm gauge so I have no clue what the rpms are. In neutral the motor seems to get to high rpms.
Not sure if its in SLOW......no alarm and revs high in neutral. Telltale stream does look a little weak.
I checked compression 125 psi on both cylinders.
Good spark at idle speed.
Pulled the Carb and dissembled cleaned and blew all passages with air. I especially cleaned high speed jet.
This made no difference.
Checks for a spun prop and found nothing.
Changed plugs for good measure.
Checked fuel pump and for leaks in fuel lines
New gas with added sea foam to it.
Fuel filter is new.
Any suggestions? Thank you in advance
Fuel filter is new.
