2004 Wellcraft 210 Fisherman Electrical
kjrichmond
Hello everyone, I recently inherited a 2004 Wellcraft 210 fisherman from my brother. It had been sitting for over a year, and needed some TLC, so after washing it, scrubbing it etc.. i have started repairing it. First, the speedo and gas digital gage was broke and the LCD swollen, i was able to purchase a NIB for 248 BUx!! GREAT DEAL Yamaha OEM too.. anyways.. thats all hooked up ...easy, and working.. My brother installed a Garmin 441 GS (doesn't work), along side a (Works)Lowrance LMS-337C DF. Said he could never get the Lowrance GPS working reliably so he just uses it for the DF/Sonar.. with that said.. i am trying to figure out were i can attach the Red wire(power) for the Garmin GPS, When i was installing the speedo, the red wire for the Garmin fell out of somewhere (not properly installed), i cannot find an electrical schematic for the switches, i know there are ACCY and other available accessories power options the black wire (ground) has been attached to the panel that is on the right side of wall under the center console. Does any one have a electrical schematic for the power panel on this boat? or can you assist me were i would attach this red wire to power the garmin, Attached you will 3 pictures of the front of the power panel, the underside of the power panel and the above mentioned ground panelGroundPanel.jpgTop_SwitchPanel.jpgUnderside_SwitchPanel.jpg..
kjrichmond
Re: 2004 Wellcraft 210 Fisherman Electrical
Hello everyone, I recently inherited a 2004 Wellcraft 210 fisherman from my brother. It had been sitting for over a year, and needed some TLC, so after washing it, scrubbing it etc.. i have started repairing it. First, the speedo and gas digital gage was broke and the LCD swollen, i was able to purchase a NIB for 248 BUx!! GREAT DEAL Yamaha OEM too.. anyways.. thats all hooked up ...easy, and working.. My brother installed a Garmin 441 GS (doesn't work), along side a (Works)Lowrance LMS-337C DF. Said he could never get the Lowrance GPS working reliably so he just uses it for the DF/Sonar.. with that said.. i am trying to figure out were i can attach the Red wire(power) for the Garmin GPS, When i was installing the speedo, the red wire for the Garmin fell out of somewhere (not properly installed), i cannot find an electrical schematic for the switches, i know there are ACCY and other available accessories power options the black wire (ground) has been attached to the panel that is on the right side of wall under the center console. Does any one have a electrical schematic for the power panel on this boat? or can you assist me were i would attach this red wire to power the garmin, Attached you will 3 pictures of the front of the power panel, the underside of the power panel and the above mentioned ground panelView attachment 160682View attachment 160683View attachment 160684..
i figured it out, had to understand how the accy 3 position switches worked, and what power connector position on the back of the switch, right side connectors, up position of switch, left side connectors down position of switch(middle position is off) ..
