2004 Mercury 115 leaks oil
finish line 88
The oil reserve tank leaks oil when the motor is in the up position. It is coming out around the twist cap (fill cap) on the oil tank. Anyone else having the same problem and how did you fix it ? Thanks
Dave1027
Re: 2004 Mercury 115 leaks oil
Replace the cap? Or do what I do, never fill the oil tank up that much.
Texasmark
Or do as I did and do both. Then you can forget it. But I had access to a gasket. Had I not, I would just have filled it 2/3 max.
Mark
