2004 johnson 25 hp
wschmpn
i got a 2004 johnson 25hp 2stroke electric start. never had a motor like this before. runs great and all but just have a few questions. how are u supposed to cut this motor off? all i can do now is pull the kill switch. also, how hard is it to change the water pump and impeller? a quick set of instructions would be great. one more thing....how much is it supposed to smoke?
Daviet
Re: 2004 johnson 25 hp
You need to get a factory manual for your engine. I beleave using the kill switch is fine. It is not hard to change the water pump, you have to drop the lower unit, thats where the manual comes in.
