2004 Johnson 140 4-stroke: fuel or other leak?
swo
My new boat (Wellcraft 180) has been in the water for only a week, and I've noticed every time I flush the motor with the flushing port at the slip (motor not running), a slick appears around the motor. If I look into the water below the slick, it's 'cloudy'. I'm guessing that this is fuel or another oil in the water, but I can't smell it on any of the flushing water coming out, so I don't know where it's coming from. When I checked the boat this a.m. at the slip, there was a slick all around the stern. Came back in the afternoon, and the slick reappeared around the lower unit as I leaned over the stern; I guess something somewhere on the lower unit. The lower unit sits in the water at an angle at about the water intakes; it can't tilt any higher because of hydraulic steering and gas line interference at the transom. <br /><br />Could any of this be due to the 'newness' of the engine (i.e. oil-based coatings or excess oils around)? I'm guessing it's fuel, judging by the way the water looks below the slick. Where would this be coming from? I'd like to have some ideas before bringing it to the dealer after break in. Thanks, <br />Tim
JRJ
Re: 2004 Johnson 140 4-stroke: fuel or other leak?
Your new rig shouldn't be leaking at all. I'd get it on the trailer and take it home. If there is a leak, you will find it. Check oil levels and look it over good. Your fuel isn't over full? Good luck.
