2004 50hp won’t start or trim/tilt
Sutty272
Looking for some help. 2004 50hp four stroke Motor had been running fine but while I was out the other day I noticed while driving that I had no tilt trim at the quicksilver forward control then when I turned it off it wouldn’t start. No noise from the solenoid just no power to forward control at all. Some of the wires to the battery were a bit corroded so have replaced sections. Only seems to be 1 fuse that I can find at engine.
engine starts with pull cord (lucky I still had it) and trim/tilt still works at the engine. Any help would be appreciated
alldodge
Pull the engine connector apart and clean the contacts.
Use a voltmeter and trace voltages from the battery to the key and at the motor
