2004 200 efi fuel pump problem
fordman77
I have a 200 yamaha that the fuel pump cuts out at higher rpms. I bypassed the resistor, no help. I can hook a ground wire up to the negative side of the fuel fuel pump and it will stay running. Does this tell me the ground circuit in the computer is bad or is there a sensor that can control that?
fordman77
Re: 2004 200 efi fuel pump problem
Changed out the computer everything works good.
