2004 115, gas in the engine oil?
TEAM56
Did the usual oil change this spring on my 4 stroke fuel injected 115 Johnson. 3 weeks into the season it started running rough and the oil light went off. I check the oil and it was about 1" over the full line on the dip stick. I changed the oil and filter agian, changed out the spark plugs, the old oil smelled badly of gas. Ran the motor about 2 hours and again gas in the engine oil. The motor runs fine at high and trolling speed, idles well. I don't want to run with gas in the oil.
Any idea what the problem could be?
JB
Re: 2004 115, gas in the engine oil?
Quite common. Go to the Engines FAQ Forum and read on 4 strokes "making oil".
boobie
Could be a ruptured fuel pump diaphram or the mtr is running way to cold or the rings are stuck.
TEAM56
I appreciate the responses, and great post on "making oil". I was aware that they made a little oil, but this must be a fuel pump or line leak. I made 2" on the dipstick in 2-3 hours of running.
Thanks a ton for the help!!
TEAM56
You were right, it's the fuel pump. Thanks again for the help!!
