2003 yamaha 2 stroke
Texasmark
Re: 2003 yamaha 2 stroke
Probably not. Best way to find out is to look at the rear of the prop shaft and the prop. If it is a thru hub exhaust and the prop shaft has threads on it it doesn't have one (splined shaft is the other way of telling but you need to look at the prop hub or shaft to do that).....things of the past...OMC (and others) boondoggle.....took the "Mighty Merc" to wake up the world. Da Daaaaaaaaaaaa.
My 2c,
Mark
