2003 Volvo Penta 5.7 Gi-E Timing
Kon-Tiki
Greetings,
Can the timing on this engine be adjusted with an advanced timing light set to 10 degrees minus 0? What does:
10° BTDC (set by calibration, not adjustable) mean?
Thanks
dubs283
Based on the photo it appears the style of rain hat is one used on an mpi/flat cap/crab cap ignition system
Idle timing and rpm are non adjustable however there is a procedure to properly install the distributor. Once the distributor is set properly the ecm controls timing and rpm
Are you having an issue you belive to be ignition/timing related?
