2003 Tracker switch wiring
rexeisenr
I'm upgrading the interior in my boat and recently purchased a 2003 tracker console. On the righthand switch panel with 3 switches, 2 of which are 3-position rocker switches (On/Off/On). On the backside, these switches have 7 pins, 3 in one row, 4 in the other row. I've been tracing the wires and I've figured out the negative and positive. However, I cannot figure out where the lead out for the two devices are. Any help would be greatly appreciated.
chuckz
Re: 2003 Tracker switch wiring
Are they lighted switches?<br /><br />Normally the switch common is in the middle and the switched legs are either side. The fourth wire maybe for a light.
rexeisenr
Yes. These switches light up when they are turned on
chuckz
Then with an ohmmeter you should be able to tell the switched legs from the light input. I don't know how they wire the light,but they probably switch the hot leg and the fourth wire is ground for the light.
