2003 Rinker 212 EFI
ccolvin
I have a rinker electronic fuel injected 220 hp when it gets warm you have to let the boat sit 30mins for it to start. the fuel pressure does not pump up when it is runnning it runs fine anyon have any suggestions I have replaced the fuel pump, fuel pressure ,regulator, siphon value, fuel cooler.
Silvertip
Honorary Supreme Mariner
Re: 2003 Rinker 212 EFI
Let the engine idle for a couple minutes before you shut it off -- especially after a long run. and then run the blowers to exhaust the hot air from the engine bay. This allows the engine to cool down and prevents the "heat soaking" you are experiencing. Fuel pumps can't pump vaporized fuel.
