2003 mercury 115 efi 4 stroke
Cruise-A-Home
I just bought this motor, it has been sitting in a field for 3 years, I cleaned it all up,hooked juice to it and it will only run if I squirt fuel through the air intake. fuel is coming in to to filter and out of the fuel pump. can anybody tell me where to look next. thanks
raymor
Re: 2003 mercury 115 efi 4 stroke
What is the fuel pressure on the fuel rail? Possible fuel pump failure with the fuel pump in the VST tank.
Jeep Man
Who leaves an 8 yr. old motor sitting in a field for 3 years? Check fuel lines for deterioration, replace filters, clean injectors and test both fuel pumps
Cruise-A-Home
There is a schrader valve on the end of the fuel rail, if I push on it , no fuel comes outwhith the motor running or not, there is also a schrader vavle on what looks like the regulator, no fuel comes out of it either.
Faztbullet
High pressure electric fuel pump is bad/stuck....
