2003 johnson vapor separator how to test
mmyers17
2003 90 hp johnson how do you test the vapor separator to see if the vapor pump is performing as it should
Thanks alot for the help
jonesg
Re: 2003 johnson vapor separator how to test
The manuals usually just say replace, but I've read guys take them apart and find torn diaphrams.
I wouldn't do that unless I had other indications such as fuel running down the back or flooding.
This forum works much better if you just lay the problem out as you understand it to be.
