2003 Glastron sx195 4.3 Volvo Penta won't crank
Engine makes loud continuous beeping sound as long as key is on.. I hear a click.. but no crank.. And the connections will start to smoke on ground leads if I attempt to start it longer than a few seconds.. All leads wire brushed and battery greased on both sides..
I see a Purple wire at starter solenoid that leads to starter relay not connected at starter and I don't see a connector for it's location?
This boat ran without mishaps last season.. No one has been near this purple wire.. Puzzled?
I pulled connector from oil pressure switch and beeping stops on starting attempts.. If I touch the open purple wire to large bolt on starter.. without key on.. it makes same loud continuous beeping sound..
Any expertise would be appreciated..
alldodge
Who winterized the boat?
alldodge
Without more info, I'm having a hard time understanding how the wires where disconnected. The ground is probably heating up because wires are not connected correctly
Do you have anyone which doesn't like ya , maybe ?
Thank you for your response.. I may have not been clear.. The 2 wires with connectors I removed to see behind them.. They were connected for all crank attempts.. The purple lead with open strands is the only wire that I am not sure where to connect? There is only one other wire connected to starter.. it is the same size as this purple wire.. it is red and yellow and connects to a smaller bolt on the starter solenoid.. Space is tight down there.. I see only the large bolt and the smaller bolt that this red/yellow wire is connected to.. there is no 3rd bolt on solenoid.. {maybe an automotive starter?}
alldodge
Guess I'm going to need to know what VP motor it is
With ground getting hot then there is corrosion on the wires. Remove the battery cables at starter and block. Clean and get shinny metal.
Don't thin its an auto starter right now.
I read somewhere that marine starters have 3 posts and automotive have only 2?
One of the pictures I attached above has the engine and serial number.. Thanks again..
alldodge
Not sure on that because even an auto starter needs at least one lead to energize the solenoid
Carb motors have used a feed from the starter to apply power to an oil pressure switch to feed fuel pump once motor has started. It also needs a lead to energize the solenoid. This type would have 2 small and 2 large terminals
Fuel injected motors don't need the additional feed
Basically a marine starter is the same as an auto starter except it has been shielded so sparks or arcs from solenoids making contact and from motor brushes are kept away from any fumes which may be near. They are ignition protected
What model motor do you have?
fetch
It is the 4.3 volvo penta..
