Streamfixer
Thread starter- Joined
- Mar 6, 2010
- 7
Just repowered from Evinrude 88 to 2003 yamaha 115 4s and Yamaha 703 remote control. I have been told need new Tach. as the 2s tach apparently will not work with a 4s. I have figured out which wire to connect to the new tach and it is awaiting the guage.
The only guages I am needing help with are the trim/tilt guage and the voltage meter. Where do I run a wire from to connect the guage to the tilt sender? Will the tilt guage from my old evinrude 2s work or do I need to get a new one?
Where do I run the wire to connect to the voltage sender?
All the guages are connected to 12v and ground.
Thank you
StreamFixer
Thank you
StreamFixer
